Oil/grease on Rear Rotor
While doing some brake work on my 04 I noticed a lot of oil/grease build up on the inside of my rear passenger rotor. I am also experiencing 3amigos plus brake light. I did the option B fix a year or so ago and it fixed them until recently.
Am I looking at just a seal, a new hub, seal and hub? What's the most affordable route to go when fixing? I've seen some crazy hub prices.
The oil/grease on the rotor is probably the axle 'O' ring shot. See RAVE page 51-1 item 2 and page 51-6 also figure M51 0052.
I had the same clag on the rear RHS rotor but no ABS codes and it was the O ring letting by on a 2003 at 120K, yours may be a different issue.
