Oil leak
Oil leak
So i have an oil leak in the front end according to a mechanic that looked at my truck today. he didn't really explain what it was or how dangerous it was to the truck.( he just said it could possibly be seals didn't say which ones??) i have 2 leaks the one in the front and on in the rear that leaks around the o2 sensor in the engine bay. what could be causing the leaks? is it something expensive coming up? i use 15w40 rotella dino.
Thanks! i will probably be doing it myself but i do have an idea of what you are talking about. As for the front main seal should i just go ahead and replace it? if so is it hard to do? I was looking at the rave and it kept directing me to different places it started me off with removing the gearbox!! no wonder they get so much labor at a dealer is there an easier way then what the rave wants?
Yes I had quite an oil leak from a valve cover, the bolts had worked loose in the rear corner. I bought a 12-point 1/4" drive deep socket set by SK, think it was about $60 but it's very shiny.
Hi ninjaff21 and Dane, hope this helps. Blocked crankcase breathers are a common problem on many vehicles. I'm not suggesting this is your problem but it might be a possible root cause.
Land Rover Owner • View topic - V8 hunting at idle
https://www.google.fr/search?q=disco...w=1164&bih=645
Crankcase Breather Land Rover Discovery Range 4 0 4 6 | eBay
