Oil oil everywhere
Old Apr 28, 2014 | 02:26 PM
jobooth's Avatar
Default Oil oil everywhere
Anyone in the Denver, CO or Castle Rock, CO area good at tracking down oil leaks? My '04 Disco is pissing oil all over itself and I feel like I'm chasing my tail. I've recently replaced the water pump, thermostat, front main seal, head gaskets, rocker cover gaskets, oil pan gasket.
I'm scared the rear seal(s) are leaking. Doesn't look like the leak is coming from the front or up high. Looks like it's coming down the sides and/or the rear of the engine. It's so bad the spray on the highway is coating my rear window. I feel bad for anyone following me.
Old Apr 28, 2014 | 03:36 PM
FlyingZebra34's Avatar
I'm up in Fort Collins right now. I'll be free this weekend if no one is closer or willing to help.
One thing that does help though is clean everything and go under when its running.
My buddies Subaru had a nasty oil leak out of no where and it was from a pinhole on the oil filter that only sprayed under high (freeway)rpms.
Old Apr 28, 2014 | 05:31 PM
Jared9220's Avatar
did you use rtv in the 4 corners when installing a new valley pan?
Old Apr 28, 2014 | 07:51 PM
MarkSF's Avatar
How to trace oil leak :
Steam clean engine
Add UV dye to the engine oil
Run it for a while
Go looking with a UV flashlight
Also works for cooling system, A/C, transmission, PS leaks etc.
Old Apr 28, 2014 | 10:29 PM
jfall's Avatar
Probably the valve cover gaskets slipped when you installed them.
Super tricky.
Old Apr 29, 2014 | 01:40 AM
dr. mordo's Avatar
Personally, I'd clean it with a few cans of brake clean rather than water because water tends to get into wires and connections and cause problems.
It doesn't have to be spotless, just clean enough to track the leak.
Are you 100% certain it's oil and not power steering or tranny fluid?
Old Apr 29, 2014 | 09:11 AM
jobooth's Avatar
Yep. I'm certain its's engine oil. Maybe I'll clean it up again and crawl underneath like ya'll are suggesting. It's elusive for certain.
Old Apr 29, 2014 | 09:30 AM
Send me your number, I am in Aurora and may be able to help you.
Old Apr 29, 2014 | 10:39 AM
SuperSport's Avatar
He's Alive!!!! Good to see you here!!!
Old Apr 29, 2014 | 02:46 PM
jfall's Avatar
Disco Mike!
The report of your demise is premature.
Pleased you are still with us.
