Oil sump
I just spent a better part of the day trying to get this thing (oil sump pan) off. I know I have all the nuts/bolts off (and a few more just for good measure) but I can't get it to budge. I can get it to wiggle a little up front but can't get it to go. Somebody must have used a lot of sealant or something.
Where is a good place to get ahold of this thing to pry it without breaking something? |
I assume you also got the horizontal bolts holding the oil pan to the transmission bellhousing?
To avoid bending the mating surface of the pan, maybe take a rubber mallet and strike the corners of the pan? Or pry against the triangular area of the rear of the pan (which extends out from the gasket area)? |
Did you get the two really deep sunk ones near the bell housing? You need an extension to reach them.
Originally Posted by abran
(Post 498173)
yes, the 2 bolts that the RAVE does not take into account
Thanks guys. I'll doublecheck when I get home. I definitely got the two forward facing ones and the 4 rear facing ones. And I think I remember getting the other two sunken ones. I'll report back later....
And yeah, it seems like I ended up with a few more than are mentioned in the RAVE. Haha. |
Originally Posted by golgafrinch
(Post 498254)
Well, it looks like I'm in good company. I saw those holes dozens of times and never realized there were bolts in there. Derp. Thanks RAVE.
But really, thanks you guys! |
| All times are GMT -5. The time now is 05:46 AM. |
