Oil in Throttle Body
Looking at my 03 Disco and discovered a fair amount of oil in the throttle body.
I did a search and found little regarding the subject. Thinking it's possibly a bad PCV valve (no codes). Any advice is appreciated. Mike |
Originally Posted by DeepBlueWater
(Post 182048)
Yes, it's usually a clogged pcv system, allowing crank gasses to back-flow into the TB.
Originally Posted by kenk
(Post 182078)
They tend to get a little dirty but if your finding oil..... You shouldn't. Maybe some debris or gunk but not a liquid type oil. |
(Post 182048)
Originally Posted by Spencerfitch
(Post 182096)
Sorry but I thought that was the point of the [PCV POSITIVE CRANKCASE VENTILATION] a clogged one will only stop this.
They tend to get a little dirty but if your finding oil..... You shouldn't. Maybe some debris or gunk but not a liquid type oil. In a correctly-functioning system, air flows only one direction, from the TB, through the driver's side valve cover, then out the passengers side valve cover into the plenum. It should NOT back-flow through the drivers side, where there is no oil seperator, hense an oily mess. A clogged oil seperator and/or hose on the plenum side usually causes this. But yes, follow ylodisco's advise, that is more than likely it. |
If the oil separator is missing it will suck in oil.
But the oil seperator is on the plenum side, if it were missing it would suck oil into the plenum, not the throttle body.
For oil to make it into the TB, the air has to be flowing in reverse |
(Post 182132)
For oil to make it into the TB, the air has to be flowing in reverse You are right and I am wrong, you make a very valid point. |
just wondering,
what controlls the way it flows? I don't see how it could possibly do that. If you ever removed the drivers side pcv hose its obvious air is coming out of it. Maybe because its unhooked [doubt it] but what in the world makes it circulate? |
