Ok, springs came, now what?
I finally got a set of DII springs and mounting hardware to replace my faulty bags, so I called my local shop and they can't quote me because they want me to come in so they can figure out how to milk me for as much as possible.
So I know some guys do this on their own, but I don't have a spring compressor or anything crazy. Is this really the 30 minute job that people say it is?
Are there any detailed pictures, instructions floating around?
there are some videos, i think. you can do it w/o spring compressor, prolly have to unhook shock.. your axle should drop far enough with the frame on jack stands and a small bottle jack placed between the frame and axle (bump stop location)
yes you can do it and yes it is a fairly easy job.
Can't I just pull the fuses? Can any shop turn off the SLS or just a Rover shop? I had no idea about the shocks.
some have problems, some don't with the fuse pulling. testbook or the like is needed to delete sls from system. dealer or not, as long as they have the equipment. I pulled fuses, relay and all sls components. I have no drain, but I do have a goofy raise the rear light, on the dash. and I have received the speed actuated chime that goes along with it, on a few occasions.
LADEROUTE
11-11-2014 10:59 AM
rchrd0413
04-22-2014 02:18 PM
greg409
08-17-2012 12:03 PM
