Oversteering after lift
Hi Guys.
I noticed that after I installed OME shocks and OME HD springs in the front, and General Grabbers, keeping the air springs in the back, that I oversteer a bit. I also noticed that it needs a wee bit of help to return to center. It likes to wander, too. It's nothing major, but it used to have 18" tires and I have ACE - it rode like a sports car. Is this normal? Can it be fixed?
Thanks!
Thanks!
RE: Oversteering after lift
ORIGINAL: Disco Mike
Pretty normal, your caster is now out of adjustment which causes this to happen.
Mine went away when installed a True Trac front diff, you can also make caster adjustment.
What did you do with the rear suspension to level it out?
Is it worth $620 for what I would get? How about the install? Can I do it in my garage? Thanks for the help!
