P0304 and Overheating
Looking for some sage like advice. Every 2 or 3 days of daily driving to work the motor will misfire and throw a P0304 code and start to overheat. I've pressure tested the cooling system with no evidence of a leak. Tested for exhaust in the coolant, again nothing. Also no evidence of anything being steam cleaned on that cylinder. Verified by visually inspecting the plug and running a scope in that cylinder. Compression is also good on #4. What should I be looking at next?
Start to overheat or it does actually overheat? Are you losing coolant? What T-stat are you running?
Originally Posted by Saturnine
(Post 642377)
Do you feel a misfire or is it only a code? Eng light illuminated? Does it immediately begin to OH heat after the misfire?
What point in drive cycle is the misfire and or OH? ...... |
if you just replaced the stat then I would guess you may need to bleed it more to cure the overheating. Very common to not get it bled completely the first time. Also seems very common these days to get bad thermostats out of the box. Check to make sure that is working too. Which one did you buy? There are several but the black one from Lucky 8 is best. Check for air in the bleed hole when the engine is stone cold. If you can add any coolant at all into that hole then you found an air pocket.
That however doesn't explain your misfire on 4. Could be unrelated wire or coil issue. |
You can feel the misfire and light flashes until it settles down. I've had it happen sitting at a light and another time while accelerating. Temp starts to go up shortly after although this last time I was about 2 miles from home when it missed and I didn't start noticing the coolant until I got in my driveway and popped the hood. Then it started coming out from that hose.
Originally Posted by Dave03S
(Post 642383)
(Post 642377)
Originally Posted by jonjmill
(Post 642381)
It's my understanding that if that temp guage moves up, you're overheating..
Without real temp readings you are clueless and we are shooting in the dark giving temp advice. ...... |
Originally Posted by number9
(Post 642393)
First course of business is to get a UltraGauge or ScanGaugeII to be able to be able to accurately monitor your coolant temps.
