P0447 purge canister vent valve
Kenso is correct. That code description is deceiving. Check the canister vent valve. If the code comes back immediately, there is more than likely an open in the wiring or the vent valve solenoid. You can unplug the sensor and do a resistance test on the valve. If the circuit isn't open, check the wiring. Sometimes the insulation gets brittle and cracks. Then it's just a matter of time before the wire corrodes.
