P1168 and P560 OBD-II codes
Could the P1668 and P560 be related? 1668 is the anti-theft open circuit and 560 is battery low. If so, who has an inkling of where I should begin checking?
Also throwing a P304 code (misfire cylinder 4) All of these started after I removed and replaced my power steering pump. Surely they're not related..... Thanks, |
So, start with the simple stuff, go have your charging system tested, voltage should be between 13.6 and 14.4 volts.
