P1415 and another potential issue
Old Oct 27, 2009 | 03:06 PM
JAC's Avatar
JAC
Default P1415 and another potential issue
My Disco is an 04 with a little over 46k miles. I've owned it since June of this year and put about 3,500 miles on during that time.
I went to Auto Zone last night on the way home from work to get a code read from the SES light that had been on for a couple of days. The code it read out was P1415. From reading threads today, it seems there are a number of possible issues. I cleared the code and will wait to see if it comes back. I'm also going to take a look at the vaccum hoses to see if something is not properly connected. Other than that, any ideas?
Now the real concern comes from some of the posts that I read last night regarding potential head gasket issues while I was researching this trouble code. My coolant was down a little, so I picked up a new bottle and topped off the resorvoir while I was at the auto parts store. It was still pretty dark when I left for work this AM, but the coolant level seemed to be okay. However, there was a little bit of white smoke after start-up. It DID NOT smell like coolant. I'm going to keep an eye on the coolant level, but is there anything else that I should do? There is no coolant smell in the engine compartment either.
One last question, if I wanted to get an accurate reading of the coolant temp one the engine is warmed up--what is the best way to do that?
Thanks again for all the help. This forum has been an amazing resource and learning tool.
Old Oct 27, 2009 | 04:10 PM
malmberg's Avatar
This is the code-
P1415 Land Rover Secondary air system fault bank 2Drive cycle D:Signal implausible
Do you hear the SAI kick on when you start your truck in the morning? I would check the SAI pump and hoses. That would be my guess but maybe someone with more experience with that code will help out.
Old Oct 28, 2009 | 07:12 AM
JAC's Avatar
JAC
UPDATE:
Before I started up this morning, I checked the coolant level. It was down a little bit and there was some white smoke out of the exhaust. The white smoke lasted for about five-seven seconds and there was a bit of a rough idle.
The Disco has 46k miles. Isn't that a bit too soon for a head gasket issue?
Old Oct 28, 2009 | 04:47 PM
JAC's Avatar
JAC
UPDATE 2:
After leaving work this evening (vehicle sat for about 10 hours), I checked the coolant level. It was right at the full mark (same level it was after I added some this morning).
There was a few seconds of white smoke, but again no coolant smell. Also, after I parked at home I noticed a couple of translucent spots on the lower driver's side of the windshield.
I was going to have a pressure test done this evening, but there was no coolant loss. I'm going to keep an eye on it over the next couple days, but should I be doing anything else in the meantime.
Thanks for the help--and at least giving me somewhere to vent.
tparsons
Dec 6, 2023 06:56 PM
Torancis_LR
Sep 27, 2015 01:23 PM
jasile
Aug 26, 2014 06:59 AM
Hyakku
Sep 17, 2010 08:49 PM
JEFIII
Sep 9, 2010 11:16 AM
