-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   PCV Line stopped having vacuum... (https://landroverforums.com/forum/discovery-ii-18/pcv-line-stopped-having-vacuum-15014/)
cptshanman Jul 29, 2008 10:43 AM
Morning everyone,
Was using seafoam to clean induction. Good suction through the PCV line initially then it stopped. No suction and unable to run remainder of can through. Any ideas what I should check? Only about 1/10 of the can went in before the suction stopped...
Shannon
Spike555 Jul 29, 2008 05:36 PM
RE: PCV Line stopped having vacuum...
Your line is clogged. Take the hose off and clean it out, then retry. If that doesnt work take a can of carb cleaner and spray directly into the nipple on the side of the intake, the nipple that the PCV hose connects to. The intake side not the engine side.
Disco Mike Jul 30, 2008 09:19 AM
In his case he should hook into the nipple area just under where the pcv hose hooks in.
