Performance accessories for 2003-04 Disco
Basically nothing you can do. Achieving anything significant over stock numbers will probably cost you more than it's worth. That would entail motor/mechanical work. Most of the issues discussed on the forum are repair/restoration related or how to prevent over heating, better thermostats, bigger fans, etc. Basically preventative stuff. However if you had the money I believe Turner engineering makes a 5.0 liter motor designed for the D2. A diesel would also be a good way to go. Torque>HP and the Discovery puts up decent torque numbers, you don't want to get too crazy with HP because the transmission won't be able to handle it.
You might be able to get a good after market air filter but I've never looked into those.
henrodstone
09-20-2014 11:24 AM
henrodstone
Headers, Intake, & Exhaust
10-08-2012 03:37 PM
g1accessories
Off Topic
01-12-2010 03:21 AM
