Pictures of coolant drains on Disco 2?
I'm trying to figure out where the coolant plugs are on my disco 2. I know there is one on each side but I cannot decipher where they are even with the Rave CD drawings. Anyone have pics?
I found the drivers side plug but no luck on the passenger.
Dont worry about them, just remove the lower radiator hose.
Can you post some pics?
EDIT:Sorry, this went into the wrong thread. |
Pics of what, the plug? I did end up also removing the lower radiator hose but I was following the manual procedure and could not find the passenger side plug, not sure it exists.
I need to change my coolant. Let me go run out and look. I have a good size lift and get under it easy. brb.
Okay, the driver side one is next to / behind the exhaust header.
The passenger side one is Right behind the Engine Mount Plate. The plate connect to the engine and the mount, there is a space for your hand to go through and you can feel it. |
