PO141
on
1 Post
RE: PO141
Changed mine last febuary. Ottawa Land Rover sells them for about $80.00 each. I'm trying to stay as away as possible from the dealer, but for critical parts like this, I felt more comfortable getting the o.e.m ones.
So yours would be the rear sensor. Make sure you get one for the rear, cause the front ones have shorter wiring that won't reach the plug-in.
on
1 Post
RE: PO141
Yep, 2 fronts before each cats, and 2 rearsafter each cats. 90% sure that bank 1 is the driver's side, and 100% sure that sensor 2 is the second one in the line, thus the aft cat one. Mine had both failed at the same time, so I had gotten bank1 sensor 2 and bank 2 sensor 2. The later, if I remember right was P0161. So by changing both I couldn't get them wrong. All this because I had the brilliant idea of trying Acetone in the gas. 10 kms later, they were cooked.
