Por 15
Old 04-29-2020, 07:50 AM
redrover75's Avatar
You should research the 3M rust Avenger, it is fairly expensive. But it converts the rust into a more stable surface, so no need to get 100% cleaned off. Really interesting product, you end up with a black, almost plastic-y surface. I have not used it for larger surfaces, but on smaller areas it works great.
Wheelspin (04-29-2020)
  #22
Old 04-20-2022, 03:58 PM
acg's Avatar
acg
acg is offline
I have a friend with a barn garage and 4 post lift. We are going to attempt POR15 as it is easily available at the Canadian Tire stores.
1) POR-15 comes in gloss black and semi-gloss black. Any thoughts on what works best?
2) They come in diferent sizes. Is one-gallon for the whole frame and axles?
  #23
Old 04-20-2022, 10:25 PM
Alex_M's Avatar
Similarly not a huge fan of POR15. If you use it, don't prep the surface. It likes the rough surface to adhere and won't stick to a prepped surface.
I've had the best luck out of plain old brush on gloss black oil base Rustoleum. Wire brush first and lay on a real nice heavy coat.
I go with gloss because it rinses down easier. Less texture for salt and the like to adhere to.
acg (04-21-2022)
  #24
Old 04-21-2022, 06:37 PM
acg's Avatar
acg
acg is offline
Thanks Alex. I appreciate the guidance.
jimvw57
Appearance & Camping Set Ups
02-24-2017 12:31 AM
Pacerlive
02-18-2016 02:23 PM
Aj6543
09-30-2008 09:50 PM
apcollin
09-13-2008 12:37 PM
apcollin
08-23-2008 08:01 PM
Quick Reply: Por 15
