possible head gasket leak
Well Mike I have talked with you before when my drive shaft broke and the garage said I also needed a T case. When I called you, you said that my T case should be fine and low and behold it was. I am going to have the head gasket replaced as you advise. I could be leaking coolant onto a head as well I suppose but the exhaust does smell sweet. The shop that is going to check my ABS codes said he would check my head for $30 so I will spend the $30 but I do believe you are right. Sweet is sweet.
LikenDisco2k
05-03-2009 08:25 PM
