Potential New D2 Owner
I've been looking to purchase a D2 for quite some time, about a year as a matter of fact. Also been a lurker on this site for some time, and finally registered a few months ago. I also have the 1500 page D2 manual on my hard drive as well.
After missing out on three bonatti gray/alpaca beige prospects (a '01, '02 SE, and '03 SE) I think I may have found my ideal D2 today (a green/tan 03 SE with 106k miles). I'll be going out to check it out later today.
This '03 is OUT of the VIN range of the block dowel/oil pump issues, but yes, I'm fully aware that there may be some '03's out of the VIN range that MAY be affected.
From what I've read on the forum, in addition to rebuilding/replacing the driveshaft and performing DiscoMike's 60k mile service sticky; I assume I'll also have to replace the timing chain and associated hardware due to mileage? Also, is the D2 driveshaft offered by Atlantic British equipped with the greaseable zerks?
This D2 (or whatever I ultimately end up with) will be a 100% on road vehicle with occasional tow duties. I'm just not an off roader but into meets/GTG's. I'll most likely mod it with 20" Stormer alloys, Magnaflow exhaust, running boards with the stainless steel edge, the black rubber door rub strips with the chrome inserts, and the OEM wood trim kit. I intend to keep SLS.
If this D2 does not have ACE, can it be retrofitted?
Thanks for whatever advice/tips you can offer.
If you want ACE buy a truck with ACE. I would guess installing ACE in a non ACE equipped truck would cost more than the entire truck. I don't have ACE and don't want it. One less thing to have to fix. My truck drives fine without it especially with new springs and shocks.
I'd like to know whether one has actually retrofitted ACE, (if it is even possible) and if its possible, cost won't be a factor as it will greatly contribute towards my comfort.
I've had a D1 and a '99 D2 previously but that was years and years ago when I lived in the Midwest and Pennsylvania where its all flat and smooth.
Nothing is impossible, you may be the first though. You would need to have the dealer program the ECM too.
I have driven in a DII with ACE and yes there is a difference but now that my truck has new OME shocks and springs I think the difference is pretty minimal. You are driving a brick on a truck frame not a corvette. I drove my truck in manhattan for 4 years without ACE FWIW.
2) I have coils front and rear, never had SLS. The OME setup offers a great ride.
Let us know how the conversion goes sounds interesting.
Moot point.
The D2 was sold as I was pulling up to the dealership (sales guy was putting on temp tags). I did look it over and it was pretty close to immaculate. It was the 5 pax version, had the cold weather package, 6 disc CD changer, navigation, and SLS. Didn't look underneath for the ACE stuff.
The hunt continues!
The hunt continues!
http://www.dap-inc.com/hawkeye/index.shtml
