Power seats won't work
If all fuses are good, and all motors are good, then it may be a frayed wire. Mine did the same thing until I put some electrical tape around the fray. You will need to take off the side seat plastics closest to each door. Then inspect the wires where the back and bottom of the seat meet. There is a piece of the seat frame there that can eventually scrap off the rubber coating on the wires with movement. Tape those up well, and put some tape on the seat frame where it cuts into it to help it from reoccuring. Takes about 15 minutes total.
goatman
01-12-2013 10:08 AM
wheelgarage
06-27-2011 01:19 AM
booper169
11-09-2010 09:10 AM
