Power steering dead on 00 Disco 2, HELP!!
Hello!
A few days ago, my power steering fluid started leaking and I could hear the whining sound every time I turned the wheel.... The next morning, there was no more power steering fluid in the reservoir. Now the noise is gone and I have no more power steering. If anybody knows, what part should be replaced? The power steering gear box, the power steering pump, the reservoir??? I would appreciate any help, suggestions... Thanks~ Sam |
RE: Power steering dead on 00 Disco 2, HELP!!
Did you add more fluid or keep driving with no fluid until the pump seized?
Do you know where the fluid was lost? Did you find a leak?
Don't drive it till you can fill your system back up with fresh P/S fluid. Based on your post, sounds like you may not be real mechanical so I would get it into a mechanic right away.
Driving without fluid will burn up your pump so fill it ASAP. |
| All times are GMT -5. The time now is 04:58 AM. |
