-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Practical Reasons for 2" lift? (https://landroverforums.com/forum/discovery-ii-18/practical-reasons-2-lift-57878/)
caymandrew Mar 25, 2013 08:36 PM
Guys,
I only get off road for fun rarely. I'm going to be replacing my shocks and wonder if I should just do the 2" lift kit? I'm wondering what other practical reasons other than better clearance off road? I guess larger tire size, what else? If I'm 90% on road will I get any benefits?
taylor15 Mar 25, 2013 08:51 PM
I know wreckdiver said his overall ride improved. I think you will gain on road by replacing the 10+ year old shocks no matter what
MC04DII Mar 25, 2013 09:03 PM
Well shocks alone won't give you a lift. You could save about $250 and just buys shocks without new springs (for a lift). That will give better ride quality. If you lift without going to a bigger tire, it will look a little small wheeled and funny.
Spike555 Mar 25, 2013 09:08 PM
To answer your question, none.
There is zero benefit to installing a lift of any kind if you are not going to run oversized tires or need more ground clearance.
MC04DII Mar 25, 2013 09:11 PM
It may discourage shorter people from riding in your truck, so there's that.
wreckdiver1321 Mar 25, 2013 09:12 PM
I don't know about that. A new suspension, especially if you're just running stock stuff now, will vastly improve the ride comfort. A medium duty kit seems the way to go for you.
Spike555 Mar 25, 2013 09:22 PM
Hey now! I'd take offense to that if I was offendable, I'm all of 5'5" and getting shorter by the year.
caymandrew Mar 25, 2013 09:28 PM
Right, well I had planned to just do the shocks as they are the factory ones, I can get her bouncing pretty good just pushing on the bumpers so they are shot. It's only a couple hundred more for the 2" lift kit including all four shocks and springs:
Terrafirma 2" Lift Kit Discovery II
The install to swap out the springs is much more involved as I'm doing this myself. But not planing on over sized tires and not needing ground clearance, I guess I'll take the easy road and just do the four shocks. Do those springs really go that bad after 12 years?
MC04DII Mar 25, 2013 09:28 PM
Well, I should have said vertically challenged people who don't appreciate jumping in a well appointed Rover. This would not apply here ;). I'm 5'11'' and have to give a little jump to get in mine.
MC04DII Mar 25, 2013 09:31 PM
Actually the spring change isn't much more involved. If I remember correctly, I had to take out the front springs to get the front shocks out. And as for the rear,those are pretty easy. Not sure how much a difference new springs would make compared to old springs and new shocks. Thing is though it will look a little off with 29'' stock tires.
