Problem with Climate Control and clock
Morning all, need to start digging into a problem today. Recently, my climate control won't remember where I had it set when I last shut off the truck. When I start the truck it will be off, when it turn it on it will have defaulted back to C, but it works fine (until I turn the truck off again). The clock is also affected, and just shows a solid green glow, with odd black streaks where it seems it's trying to "paint" Any starting ideas? Fuses and wires? Thanks in advance!!!!
you have a short somewhere or potentially corrosion. You could buy a used climate control unit and see if that fixes it, or trace the wires back to the fuse box and see if any wires have worn through. You’ll probably have to remove the radio and such as well to see back there
Chris Gregson (06-12-2021)
