-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Problems discovery 2 automat (https://landroverforums.com/forum/discovery-ii-18/problems-discovery-2-automat-111698/)
dino7 Apr 17, 2022 10:54 AM
Hello. I have a problem with my Discovery-2 As I was driving and suddenly stopped as if the lever went to the parking lot. Some ideas of what may have happened.
Harvlr Apr 17, 2022 11:42 AM
You’ll have to explain that in way more detail. You were driving and the vehicle suddenly stopped, as if the drive train seized up?
dino7 Apr 17, 2022 01:27 PM
Yes, something like that happened. I removed the rear cardan shaft, but it still doesn't work. I also removed the front cardan shaft and then we pulled it home. Did something happen in the gears or in the transfer box. I have no explanation.
It turned out as if during the movement the lever went to the parking position and the jeep crashed. I turned off the bike and after 5 minutes started it I tried back and forth, but it only moves about 5-6 inches. So far I have not had any problems with the transmission. We do not have Discovery services here, so I ask you for advice on what to do. Thanks in advance.
jastutte Apr 18, 2022 12:47 PM
assuming you are actually talking about a Land Rover Discovery 2 and not a jeep or bike, i'd check the fluid in the transfer case first.
if empty or really low, refill and try to drive it. though, it may have broken some internal gears if you ran dry on fluid.
dino7 Apr 18, 2022 12:55 PM
Thanks. Tomorrow we will check and write.
Harvlr Apr 18, 2022 02:15 PM
Do you mean that while the vehicle was moving you put the transmission shift lever into the park position? If so, the problem will likely be inside your transmission.
adalton Apr 19, 2022 06:43 AM
I am laughing so hard at this.
dino7 Apr 20, 2022 08:45 AM
Hello. Today he found out that the transfer box was broken. Where can I find a second use one.
jastutte Apr 20, 2022 10:18 AM
what is broken specifically?
your best bet is to source a used transfer case local to you. junkyard or a Land Rover specific breaker.
dino7 Apr 21, 2022 12:04 AM
Hello Will it be from a manual transmission or should I only search from an automatic.
