Proper lift points???
Does anyone kow what the proper lift point are for a 03 Disco? Pics would help.
RE: Proper lift points???
Lift or recovery points?
If you are wanting to jack up a wheel, I alway recommed putting the jack uner the axle housing or shock area, as close to the wheel as possible. Does this help? Mike |
That helps some but Im talking about and actual lift. 4 point shop lift.
I vote for the frame.
Lifting by the luggage rack can cause minor damage to the roof...and the luggage rack. |
Depends on what you are lifting it for, you can lift the frame and hange the tires or lift the axles if you don't want the suspension strong out.
Mike |
