Proud New DISCO 2 owner
Just made the plunge and bought my first Land Rover. 2001 104K $4500. The person that owned it apparently read up on here on what to do. Front drive shaft replaced with zerk fittings on it. New plugs and wires. Radiator has green fluid and has been flushed recently. NEW HEAD GASKET!! Looks like the head has been machined and no sign of leaks. New Mass Airflow sensor. New brake pads and rotors and nitto grappler All terrains all around. Some dampness on the transfer case but I can fix that soon. Oil was still light brown so it looked real clean. Brake fluid looked brand new. I feel like I got a really good deal and for now it seems well maintained, we shall see . I went ahead and kept 1500$ in the bank just in case I need some parts. I am military so we have a very good auto hobby shop and all tools accesible to us. Lift 2.50 an hr and tools are free to use. I worked on Aircraft for the past 5 years so I think I can handle most maintenance with the manual. Anything else I should check or service that might have been missed? Thanks in advance.
Now James...don't go and scare the man off....them boys don't hit that hard.....ok well maybe sometimes....
Welcome BigCraigMan! Spend as much time as you can reading these threads and you will learn a lot in a short time. Don't be afraid to ask a question. And for God sakes don't think everything on here is the gospel either. Join a few other boards and spend some time with the RAVE. You will be just fine. Also not sure where your stationed but try and locate you a good salvage yard near you that has the Disco's.
