pulsating after brake job.
I just replaced rear rotors and brake pads with the akebono pads and flushed out and replaced brake fluid with dot4. Im now getting a slight pulsating feel in the brake pedal with moderate braking, its not the rapid abs pulsate that you get when stopping on slippery surface its more of a slower steady pulse. There are no abs or traction lights on of any kind. The one thing I noticed during installation is the screw that goes in each rotor to attach to hub was missing on both sides, I did not replace them thinking wheel pressure is more then enough to hold rotor to hub. Also, I have only a couple hundred miles on new brakes and the cross hatching on rotors is still not worn, could the brake pads just need more time to "break in"? Any thoughts?
If the Rotors are not fixed in position, it is possible some debris shifted between the Rotor and Hub. It does not take much to cause the Rotor to not be parallel anymore. The easy way to check is with a dial-indicator mounted to body or suspension, measure the run-out of the rotors. If the rotor is not true, take them off and clean the surfaces where they mount to the hubs.
TRIARII
10-14-2013 10:33 AM
Foe
08-03-2009 05:05 PM
