QT Diff Guards Install Fitting Instilation Instructions
Here is quick install with pictures for the QT Diff guards. It is very self explanatory but there are no printed instructions I have found. I though I would do a small write for the less mechanically inclined among us.
Rear Diff install first
Loosly tighten up this bolt to hand Diff Guard https://lh3.googleusercontent.com/-K...to%2525205.JPG Here I am fitting the QT Diff guard and a RockWare Pinion guard. I decided to ditch the pinion guard and just use the diff guard as is. I may add a pinion gaurd to the front of the diff gauard later, by welding a small piece of steel on. https://lh4.googleusercontent.com/-N...to%2525203.JPG Installed! https://lh6.googleusercontent.com/-v...rDiffGuard.JPG Next installing the weld on tabs for the Front Diff guard: Screw in the tabs with the provided bolts, tabs go to the inside of the diff gaurd. Now line up the front diff guard by bolting up the rear bolts. Turn the tabs so the best contact the diff to your liking. Use a paint marker to outline where you should grid the diff so you can weld on the tabs Remove the diff Grind the areas marked with a angle grinder http://img.auctiva.com/imgdata/1/3/2...94127347_o.jpg http://img.auctiva.com/imgdata/1/3/2...94127405_o.jpg Now weld the tabs with the diff guard bolted up with the rear bolts holding it up. http://img.auctiva.com/imgdata/1/3/2...94127328_o.jpg Here are my welds not pretty but strong. The drivers side fit very close on the tabs. Passengers side had almost a 1/4" gap, I filled it with weld. Its not going any where now. I will prime and coat the welds and tabs black when I paint by bumper in a week. http://img.auctiva.com/imgdata/1/3/2...94127426_o.jpg http://img.auctiva.com/imgdata/1/3/2...94127389_o.jpg Now when you change your own oil you get to look at this. http://img.auctiva.com/imgdata/1/3/2...94127368_o.jpg |
Bump this. Front QT installed with weld on tabs.
So no one thinks my diff guards are cool huh. Thats Ok! bumped to the 2nd page 2 days in a row with no comments. I see how it is :)
how did I miss this the first time around?
STICKY TIME! Thanks as always for posting your how-to's, you're a champ and I envy your truck and the upgrades you have done to make it your own.
http://freeemoticonsandsmileys.com/a...ons/cheers.gif |
I'll bump this, since I just won this! :)
Thanks for posting pics of this. |
Boss, how do you like these? Have you ravaged these on the trail yet and have they held up? Was thinking of making my own but in the interest of time I might just buy em... let me know. Thanks
