Question about dif/t-case seal replacement
Old Mar 1, 2009 | 07:54 PM
Tapper's Avatar
Default Question about dif/t-case seal replacement
I had the dealer replace both the front/rear dif pinion seals, and also the t-case pain seal. Done under warranty. The advisor said that they would probably change the fluids as part of the service. When I looked over the invoice, it said that the fluids were topped off. My question is can the seals be reaplced without changing the dif and t-case fluids. Thanks.
Old Mar 1, 2009 | 08:23 PM
roverguy7's Avatar
the diff seasls can be replaced without draining any of the fluid. and it depends on what was replaced/resealed on the tbox. either pinion, they dont need to, and it really isnt part of the job to do, if it was the lower cover, it was drained and refilled.
Old Mar 1, 2009 | 09:06 PM
Tapper's Avatar
Can you tell what they did the the t-box by the parts list.
STC50550 Gasket $20.94
42404 Met Class 8 He 8x0.28=2.24
42464 Met Unhardened 8x0.06=0.48
42052 Met 8.8 Hx HD 8x0.38=3.04
Labor 101.20
Total 127.90
Old Mar 1, 2009 | 09:42 PM
roverguy7's Avatar
no, im really not sure, i cant think of any actual gaskets on the case, its all just rtv seals, three shaft seals, and an o-ring for the intermediat shaft. and the rest of those parts apear to just be nuts and bolts, given that there are 8 nuts and 8 bolts, id say flanges, but i cant figure out what the 8 42464's are, what the hell costs 6 cents these days
Old Mar 1, 2009 | 10:08 PM
Tapper's Avatar
Is it safe to assume that if they did not list any fluids, it was not changed. Just trying to figure out what needs to be done for my 60K service.
Old Mar 1, 2009 | 11:01 PM
roverguy7's Avatar
not really, differential fluid is usually stored in bulk, that is its not in the parts department, rather in the shop, and the tech would have to tell the parts department to bill it out, which is not always done, the tech does the job and grabs the fluid. however, i would go ahead and replace the fluid anyway, wont hurt anything and the fluid isnt too pricey
Old Mar 2, 2009 | 03:02 AM
Urban Panzer's Avatar
Google is your friend,
Part number / product here
http://www.lrseries.com/shop/product...-ADHESIVE.html
ATXDisco
Aug 12, 2011 06:10 AM
yloDiscoII
Feb 10, 2010 10:03 PM
Tapper
Feb 3, 2009 09:35 AM
Trapshooter
May 11, 2008 11:51 PM
Mountainman
Defender
Jul 5, 2007 04:57 AM
