Question on changing temp display?
This is probably a dumb question but hear goes anyway. Is there any way to change the temperature reading on the air/heater and outside temp display on my 02 Discovery from Celsius to Fahrenheit?
Thanks. |
Yes, yes there is.
Its in the owners manual. Land Rover Parts & Rover Accessories From Atlantic British | Discovery, Range Rover, LR3, LR2, Defender, Freelander and Land Rover Series Parts & Accessories, tech tips on the bottom of the page. Or search on the forum. |
Found it thanks.
If you ever unhook the battery or need a jump start you will need to change it again, so print that page out and throw in the glove box or dog ear the page in the owners manual.
Will do. It was very easy to do, just did it. Thanks again.
Temperature conversion (°F - °C) conversion has taken place.The temperature displays can be converted to or from Fahrenheit and Centigrade, as follows: • Press and hold the air recirculation button. • At the same time, press and hold the on/off button for 3 seconds. • A ‘beep’ will sound to indicate that the Note: it is unethical to do this if the driver is a TV weathercaster. They must do the calculations in their head, just like all science teachers can, quickly, quickly! |
or you could simply learn Celsius... it is a better and easier system of measurement and the REST of the world uses it.
"better" is open to debate. Fahrenheit has a higher degree of precision due to the 180 degree span between freezing and boiling points of water. Celsius is easier to work with do to it's 100 point span.
