quick question, quick response Please!!!
When you erase a code (large evap leak) do you also erase the driving cycles. Very quick summary: Battery was disconnected for a couple of weeks while changing out coil packs, plugs and wires. Vehicle failed inspection because drive cycles went away and evap system showed as not ready...Posters here pointed out vehicle had to be driven to reset drive cycles...Husband filled gas tank and we drove. Once drive cycles reset, vehicle popped a large evap. leak code. Checked gas cap, was not properly sealed. Need to take for inspection, can we erase the code and go, or do we have to reset drive cycles all over again?
Many thanks for all help so far. Most have proved to be right on the money! |
erase code and go
Originally Posted by hilltoppersx
(Post 192912)
erase code and go
Originally Posted by Spike555
(Post 192926)
I'm not 100% sure on that, I do believe that erasing any codes resets the whole ECU and you will need to do another drive cycle.
(Post 192926)
(Post 192926)
I believe that is correct, Spike. Once the ECU has been reset, it is going to take different drive cycles for all of the equipment monitors have run. I further believe (my city does not perform emissions tests) that the first thing an emission station station does is to make sure the SES light performs its self test (illuminates when key on), then, if it goes off as normal, they check to make sure all the monitors have been run. This is to make sure someone doesn't have a serious emission problem, and clear the codes right before testing. Bottom line (and I am 99% sure on this) is: You are going to have to fix the problem, then perform however many drive cycles it takes for the ECU to make sure that passes. Last time I checked, there were something like 8 different drive cycles for these things, depending on what the monitor was for. |
| All times are GMT -5. The time now is 07:14 AM. |
