Radiator fan stuck
Any techniques to remove a radiator fan? I tried soaking to Pb blaster/ liquid wrench, heat etc and still wont budge. Ant tool to hold pulley down so it wont follow? Thanks |
Originally Posted by LR03NJ
(Post 667770)
I bought on Amazon because I can use both sizes but the Rover is the 36mm. The tool with the holes holds the pulley.
http://www.e28-m5.com/wptool.jpg |
You might be able to rent those tools, I know i can up here in Canada.
You can rent the tools at Advance Auto or Autozone
I bought these for the tool box. The pulley holder is a must have in my world. |
All you need for the pulley holder is a piece of 1 inch strap steel from The Home Depot or Lowe's. Cut it to 18 or 20 inches and drill a hole in one end.
Thank you all for all the directions you gave me! Cheers!
