Radiator Out, Questions About Screws
Hello everyone,
I took the radiator out today of my 04 D2 SE and i have some questions about the screws used in the radiator mounts.
i looked up the part number in my parts list and was unable to find it.
Are all the Phillips head screws the same? The screws I am referring to are the fan shroud screws, the two bracket screws, the two middle mount screws.
as well, is there a bolt or a different screw I could use on the top? If not I think I’ll use two or three washers with the fan shroud screws
Thanks
Thanks
As Dave03S said. This is potentially a huge fail if the screws get mixed up. When I did my radiator change I measured the distance (about 5/8" I think) to the tank and made sure the screws were considerably shorter. I only knew about this by reading before I did the swap. If not I could have easily ran the wrong screw in and ruined a new radiator. The screws only need to thread in a little to do the job. Recently I bought shorter replacements and ground the ends flat to be safe.
