Radio signal is weak, only receiving one channel, and its weak-Suggestions :
2001 D2; my radio signal is very weak. I only get one channel in my area, and it is very weak.
I suspect that the antenna is not plugged in to the radio head either behind the radio or the antenna (in the rear door glass??) is not connected properly,..but wanted to check here first to see if there is a recognised common problem. No results found in 3 searches. Also, How do I get the radio out of the dash and how does the rear door interior panel (if that is where the antenna is. BC |
Have you not downloaded a copy of Rave?
These type of questions are the things that take all of 30 seconds to answer by opening the pdf and typing "radio" into the search box. |
