-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Rain water leaking into DISCO front driver side- Any suggestions? (https://landroverforums.com/forum/discovery-ii-18/rain-water-leaking-into-disco-front-driver-side-any-suggestions-7034/)
DV57 May 26, 2007 03:05 PM
hi all.
just wanted to get any advice on rain water leaking into the driver's side pillar at the top of the windshield.
the land rover dealership said its common on the discos and that it needs to be sealed.
i don't feel like driving to the dealership just for this one thing- has anyone fixed this issue before by themselves? if so w/what?
thanks.
Disco Mike May 26, 2007 03:59 PM
RE: Rain water leaking into DISCO front driver side- Any suggestions?
If it is just your windshield leaking, any auto glass shop can reseal it.
Mike
DV57 May 26, 2007 04:14 PM
i'm pretty sure it's not the windshield.
how can you tell it's the windshield? i have no cracks or chips
Disco Mike May 26, 2007 04:49 PM
You have 2 things that will leak water in the area, a bad seal on the windshield or a leak from the drain hose from the ront sun roof.
Mike
DV57 May 26, 2007 09:59 PM
its looks like a bad seal on the windshiled.
disco mike, do you know how to fix it?
root44 Oct 1, 2007 03:39 PM
I am experiencing what appears to be a similar leak as the poster.
Where does the sunroof drain line run, and if leaking where would the water first appear?
thanks
russ
98roverguy Oct 1, 2007 05:15 PM
Solution:
Grab a golf ball and chuck it at your windshield. Call an autoglass company and they will replace all windshield seals including your ruined windshield. Insurance will cover all of it.
okdiscoguy Oct 1, 2007 08:36 PM
if you carry full coverage....
If it is the sunroof, I think it frist comes around the corners of the headliner. I don't have sunroofs and can't be certain. The windshields are common and prone to develope leaks about 6 inches in from either side.
