Rear cargo door latch problems
Hello lads,
I have an ongoing problem with my rear cargo door latch on my 1999 Series 1.
I go to slam the door closed and the door just bounces open again, not latching. Sometimes if I lock & unlock several times on the fob and try again, it works.
The dealer replaced the door mechanism last year when it was acting up, now it started again. I have had to secure the door with a ratchet strap between the safari roof rack and the ladder on the door.
Anyone else had this problem? How did you fix it?
Cheers,
Tony
Cheers,
Tony
Hello lads,
Cheers,
Tony
Cheers,
Tony
I have this problem, many on this forum suggests to pop the green LR oval above the plate and lube the mechanism and spring.
Also clean the tracks below the door and lube it really well too.
jigray3
07-30-2019 07:52 PM
