-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Rear door adjustment?!?! (https://landroverforums.com/forum/discovery-ii-18/rear-door-adjustment-40502/)
IDAHO May 4, 2011 04:51 PM
So I drove around for a while with my rear door fully open (don't ask...) and now it's hanging low...in other words, when I try to close it I have to lift the door to get it to line up. Is there a known method for adjusting the hinges? I noticed two round plastic covers in the door by the hinges and they reveal a small bolt head. Is this an adjusting bolt?
I already tried loosening the hinge bolts and shifting it around a bit, but as with other shtuff I try it did not end well. Let me know if you are a door guru....I'm also having trouble with the lock sticking, but I'm pretty sure that's associated with the door being out of whack.
I'm sure it's also completely possible that I have completely bent the hinges....
good times!
IDAHO May 4, 2011 04:53 PM
Oh....it's an 01 discoII....
jafir May 4, 2011 05:41 PM
Do you have the RAVE manual? If not, download it from www.landroverresource.com
It has a section on removal and refitting the tail door, with a blurb about adjusting it. It basically say don't tighten the hinges all the way, move it around until it's right, and then tighten them down. There are drawings too.
IDAHO May 4, 2011 06:10 PM
Yea, I have it....I didn't think it would have anything but removal...sweet!! Thanks.
