Rear Door Lock Solonoid Question
Ok,therear door on the drivers' side has neverfully unlockedsince I've owned the vehicle (98 Disco). As I look at the situation, the solonoid seems to pull down firmly and pop the lock button what appears to be all the way up. But when I attempt to open the door from the outside, itwon't open. Digging in a little more, it seems that the horizontal rod that goes to the latch assemblyis about 2mm from full travel (unlock point) when the solonoid attempts to 'unlock' the door. If I pull the door unlock **** up just a smidge more, the door unlocks and opens fine.
Examinging the solonoid, itpulls down frimly, but doesn't stay down (seems momentary). Is that the way it's supposed to be?Is the issue that the solonoid doesn't 'hold' the rod down firmly? I moved the mounting plate up/down to see if a slight amount of adjustment would help but it didn't.All the linkages arewell lubricated and nothing is catching. Just want to get your advice before I spend the bucks ona newPDL solonoid.
Thanks,
Thanks,
RE: Rear Door Lock Solonoid Question
Your door lock actuator is bad, no big deal. www.roverlandparts.com for a newuesd one.
I noted your issues with your door latch/lock. I have the same issue going on. I need to pull the door **** up ever so slightly to get the latch to catch release the door lock. I can also get it to catch if I turn the key all the way while in the lock and then pull the door latch.
It will also relock on its own if I shut the door, without hitting the lock button on the key fob.
I have spent hours trying to figure out the issue. I looks like the release lever just slides forward a hair, enough not to catch the door lock lever. I thought that something might be bent (teenage boys horsing around with the door)
Recently, rear driver's side door will unlock fine but when I try to open it from the outside it seems to relock just before I can get the door opened. Gremlins seem to always come out just before Christmas!
Do you think that this is an actuator issue or an adjustment issue? Thanks Phil
1999 DI SD 102k miles Oxford Blue, Tan Leather interior, NO CEL! Running great, getting marginal mileage around 11 in the city 16-17 on the road at 75 mph
bcolins
11-08-2011 06:15 PM
