Rear door won't open
Any ideas?
The handle feels like it's already been pulled. I can get my fingers in there and push in back into the non-pulled position a bit and then pull it, but that does not seems to help. The inside one feels similar, except it springs back when you let go of it, unlike the outside one.
Any tips?
Thanks
MAx
Any tips?
Thanks
MAx
Welcome to the club. My rear hatch is acting up as well. Yours sounds like a lubrication issue. You may need to remove the door panel and take the entire mechanism out and clean it. I would try spraying wd40 through the slot where the door pull connects to the lock (just above the license plate on the right side. Also, pry the land rover badge off the door handle and shoot some in there too. After you clean it with wd40, spray white lithium grease after a few hours.
Share your own customer images
$3.49 + $3.54 shipping
In stock. Processing takes an additional 3 to 4 days. Sold by Denny And Kathy's Superstore
Quantity: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
or Sign in to turn on 1-Click ordering.
More Buying Choices
Amazon.comAdd to Cart $8.15 & eligible for FREE Super Saver Shipping on orders over $25. Details
Geroy'sAdd to Cart $4.34 + $5.20 shipping
MidwayAdd to Cart $3.99 + $5.69 shipping
18 new from $3.48
Blaster 16-PB Penetrating Catalyst - 11 oz.
by B'laster
4.2 out of 5 stars See all reviews (16 customer reviews)
16 Reviews
5 star: (12)4 star:
(1)3 star: (0)2 star: (0)1 star:
(3)
› See all 16 customer reviews...
| Like 1308621182 false -1 0 0 0 (0)
List Price:$5.29Price:$3.49 You Save:$1.80 (34%) o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o
In stock.
Processing takes an additional 3 to 4 days for orders from this seller.
Ships from and sold by Denny And Kathy's Superstore.
18 new from $3.48
Common issue. Next time use a little screw driver to pry off the land rover logo on the rear handle. It's actually a plug and when it pops off you will have access to the return spring mechanism. Spray the springs and pivot down with wd40 and work the handle. It will come loose and start working again. No need to take the door panel off.
If the actuator itself is bad, lubricating the return spring and linkage won't help. That is what's up with my rear door at the moment. I read a thread where someone replaced the 12v motor but it is not that simple on the rear actuator. BPUtah has genuine LR replacement actuator/lock mechanisms for $157. That's the lowest price I found for a new one.
