Rear drive shaft conversion
I destroyed the new rotoflex wheeling at Hidden Falls, i dont think i want another rotoflex so the ujoint conversion is next then.
Do i buy a conversion kit from L8 wheel it then upgrade the shaft or buy the upgraded shaft from the get go and not worry about it.
So this kit
Lucky8 Llc. - Take the road less traveled...
or
The conversion flange
and
Tom Woods rear two joint drive shaft
thoughts?
So this kit
or
and
thoughts?
I installed the L8 on mine recently. I do have some vibration at higher speeds but not 100% sure if do to the lack of a rotoflex or because I also removed the weight on the differential. Mine was a pain in the *** to remove. If I was to do it all over again I would just purchase a used front diff and slap it on the rear. Granted you have to pull the rear axles to do this, but in my experience it was much easier then removing the parts for the flange. I have a post on here somewhere showing the carnage.
I know this is an old thread. i have 2001 D2 with stock rear shaft with 118k miles.
I need to replace the the Ujoint. I am thinking about the conversion kit. I have no vibration or anything just need to the preventive maintenance
I read many places that Rotoflex prevents vibration and the pain to replace the Flange.
I am not totally sold on conversion as that introduce another Ujoint to deal with. anyone had issues after conversion?
Thank you for your help
My personal experience was that there was no change in vibration after converting to universal joint. I agree that just swapping in a front diff is sometimes an easier option. That's what I intend to on my next one because I have a spare front diff.
DiscoJon
07-14-2019 01:51 PM
shooler
03-09-2012 09:49 PM
TripleThreat
04-12-2011 08:58 AM
Randy P
10-10-2007 03:25 PM
