-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Rear Panhard Conversion (https://landroverforums.com/forum/discovery-ii-18/rear-panhard-conversion-61654/)
ZGPhoto Sep 5, 2013 10:49 AM
6 Attachment(s)
As per popular request, I have decided to do a thread on the panhard rear conversion. I am not stepping in uncharted territories, and it is not the end-all solution for ultimate articulation by any means, I just want the info out there. I'm sure a lot of you know this, this is for those that don't.
Basically the idea is that with a watts linkage, you have reasonable articulation until a certain point where the linkage binds and there's no more give. There are ways around this, RTE has an extended watts linkage, as does Lucky8. I did not want to stay with the watts linkage as it's more complex and expensive to replace the bushings WHEN they DO go.
The benefit for a watts is definitely there, because it moves in a straight line essentially.
http://upload.wikimedia.org/wikipedi...ts_linkage.gif
However, there is a curve and end to that line. Here is a panhard, it curves but allows for more movement.
http://image.sporttruck.com/f/985910...anhard_bar.jpg
I ended up buying the Ruff Stuff Specialties Panhard kit. It is a very nice kit that is all inclusive, everything you need to do the conversion comes with it. It is important to specify axle offset bracket and frame outside panhard. It can be found here: Panhard Kit - RuffStuff Specialties
Here's a photo I took of what I received in the package:
Attachment 57021
Basically you remove the Watts linkage, grind down the outside where there's that little bracket that hangs back, and weld the new brackets it. I am no good with a welder, so I had Don Trudeau of Portsmouth bang out the job for me. He did a great job and I highly recommend him. He did it to his own truck before mine.
Attachment 57022
And here it is finished:
Attachment 57023
Attachment 57024
Attachment 57025
Attachment 57026
As you can see it is coated in underbody spray, as we get a lot of corrosion in the North Eastern states.
Cheers,
Zack
coors Sep 5, 2013 05:32 PM
That's quite the engineering feat you have there Zach. How about some real world poser shots!!
Better put in some spring retainers they might pop out on you.
ZGPhoto Sep 5, 2013 07:02 PM
1 Attachment(s)
Shocks won't extend long enough for the RTE +3 and 1.25" RTE spacers to dislocate.... yet. Bilstein 7100s on the way!
Attachment 57018
Fivespddisco Sep 5, 2013 07:56 PM
Nice post Zack.
ZGPhoto Sep 5, 2013 08:01 PM
Thanks Justin, you like that red diff up there? I've got christmas axles....
coors Sep 5, 2013 08:19 PM
Nice!! From the pics it doesn't look like you have the rear spacers in. Are you still running them?
ZGPhoto Sep 5, 2013 08:21 PM
Yep, I do! As you can see the ring that the spring sits on is flush with the axle bracket that the spring seat mounts to, the spring seat itself is around 1.25" tall.
coors Sep 5, 2013 08:50 PM
Gotcha. Hey, how are your ABS leads? They look fairly close to being stressed in some of those pics.. Keep an eye on em.
ScreamingLife Sep 5, 2013 09:15 PM
Love it! Thanks for the update! I will look into this once I'm done with my swap.
ZGPhoto Sep 5, 2013 09:21 PM
I got the extensions from another forum member here, should be fine. I'm more worried about the brake lines.
