Rear Park Assist
Rear Park Assist
Searched the DII forums, and did not readily see anything on this. Is it possible/practical to add the rear park assist option onto a 2004 Disco SE? Would it typically be prewired for this? Vehicle is for my daughter, and just trying to give her a slight edge in that department...............Thanks.
An 04 vehicle will be wired from the binnacle to the LH rear wiring compartment.
There will be a pre-wired switch connector clipped into the rear of the switch blank in the bottom left position in the binnacle.
Behind the LH grill in the load compartment, you'll find the connectors for the PDC ECU -
C0957 and C0958 are for the PDC ECU
C0987 is for the PDC speaker
Here's a clearer picture of the three connectors -
You will also require the rear bumper harness and sensors.
Underneath the vehicle, in the LH rear corner, you should find the 6-way connector where the bumper harness connects -
From Land Rover - Part number YMD001410 (callout 1) -
YMD001410 | REAR PARKING SENSOR LOOM DIS11 | Land Rover | Discovery 2 - 1999 to 2004 | Britcar (UK) Ltd
Unless you can pickup the parts cheap from a scrap yard, they cost a fortune new from Land Rover.
You would be better off fitting an aftermarket kit from eBay.
If you were to fit an aftermarket kit, there's an ignition-switched live (Light Green/Orange trace), and reversing lights circuit (Green/Brown trace) in C0958
luxury1
12-16-2008 02:13 AM
