lndrover@carolina.rr.com |
01-29-2015 07:48 AM |
Rear passenger windo disco II 2000
Have a 2000 disco that I keep mint. Bought in knew. Having a issue with my drivers rear window. I have replaced window regulators before. But in this issue the window simply does not go up or down. Motor not working. Never use the rear windows. I have been told that the motor may just need to be taken out tapped on and run. Might be stuck from lack of use. Im told this is a common issue. I have checked the fuse it is fine. Any suggestions. Thank You.
J. Ferguson
