-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Rear wiper question? (https://landroverforums.com/forum/discovery-ii-18/rear-wiper-question-53908/)
mx468 Oct 31, 2012 12:15 PM
Does the rear wiper suppose to swipe continuously or intermittently? I just noticed that it swipes 3 times than stops, than 1 time every few seconds?
mattmo78 Oct 31, 2012 12:18 PM
Believe that's normal. When you first turn it on, it will clean the window, then it's basically just keeping up after that.
coors Oct 31, 2012 01:15 PM
My '01 cycles one time when first energized "on". Then it swipes simultaneously w/ the front wipers.
Disco Mike Oct 31, 2012 01:23 PM
Pretty much normal. It will also swipe when you are running the front wipers and you back up.
Bkreutz Oct 31, 2012 08:24 PM
From the owners manual......
Rear window wash/wipe
Press and hold switch for the
required duration of window
washing. The wiper operates automatically
during washing and continues for a further 3
wipes after the switch is released.
Rear window wiper
Press to operate: after
continuously wiping 3 or 4 times,
the wiper operates intermittently until
switched off.
NOTE: When reverse gear is selected, the rear
wiper will operate (either continuously or
intermittently) in tandem with the front
wipers.
