Reconditioning Estimate...
I would like to see if anyone on here had an educated guess or guesstimate on what an Independent shop would charge for the work below:
Front Rotors
Front Pads
Rear Rotors
Rear Pads
Brake Fluid Flush
Coolant Flush
Low Temp Thermostat Swap
I received a quote from a dealership (all oem parts) and even with my "VIP/Loyalty Discount" it appears to be too steep to entertain and I am considering alternatives (Independent shop w/ Aftermarket Parts) and if all are unreasonable then doing it myself when I have the time. Any pricing information would be appreciated.
Front Rotors
Front Pads
Rear Rotors
Rear Pads
Brake Fluid Flush
Coolant Flush
Front Rotors
Front Pads
Rear Rotors
Rear Pads
Brake Fluid Flush
Coolant Flush
Front Rotors
Front Pads
Rear Rotors
Rear Pads
Brake Fluid Flush
Coolant Flush
Guys on this forum will be more than helpful to guide you through, and you'll feel like a boss when you've completed the work!
iconoclast (08-09-2016)
Front Rotors
Front Pads
Rear Rotors
Rear Pads
Brake Fluid Flush
Coolant Flush
Front Rotors
Front Pads
Rear Rotors
Rear Pads
Brake Fluid Flush
Coolant Flush
The following 2 users liked this post by matt3502:
dgi 07 (08-10-2016),
Labor is like 120.00 per hour and a complete brake rotor/pad job on all 4 corners can certainly be done in an hour!
Part wise you can get 4 Cross Drilled/Slotted Rotors, and Ceramic brake pads F/R for 210.00 off of Ebay for Brake Motive (aka Power Stop) products. Job should without a doubt be less than 500.00.
The following 2 users liked this post by Best4x4:
