-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   removing rear door trim piece (https://landroverforums.com/forum/discovery-ii-18/removing-rear-door-trim-piece-40461/)
grandkodiak May 3, 2011 09:23 AM
lookin through rave it says to remove the handle and speaker, then remove 20 clips along the outside. do these clips slide up, down, to the side? or are they pin type that pop stright out back?
Bundu May 3, 2011 09:51 AM
Plastic pin type, half will break.
grandkodiak May 3, 2011 09:53 AM
yey lol. im just gunna do a few on the top i think just to run a wire for the cb like someone posted up not to long ago... never noticed that wiper grommet opening behind the spare! good stuff haha
Bundu May 3, 2011 10:59 AM
Find a long flat object to pry it open, or one of those panel poppers.
ajmille May 3, 2011 05:55 PM
buy a trim removel kit, they are made out of plastic,and several different sizes and shapes come in the kit, if you go to www.eastwoodco.com they sell the tools, the tools are worth the money as they will be cheaper than the poppers and it will save you loads of agrovation as well as you wont scratch your paint.
ajmille May 3, 2011 05:58 PM
p.s, if you do brake one or several, take the broken ones, smooth out the broken bit it leaves behind on the top and reinstall,
grandkodiak May 3, 2011 05:58 PM
i managed to only break 3 on top, but saved 4... enough to get my hands down to remove the weather cover. now, i got the camera wire through the wiper port, but there is no way im gettin the CB cable through it :( Def going to have to drill it bigger and find a new washer... but i dont have a drill, nor do i ever modify body panels haha so the cdb-ant will remain sittin comfy in the back seat lol.
yloDiscoII May 3, 2011 06:46 PM
Originally Posted by grandkodiak (Post 243367)
......but there is no way im gettin the CB cable through it...
Damnit, I was going to attempt to wire up my CB antenna this way over the weekend Thanks for saving me some frustration.......Home Depot grommet isle here I come!:D
grandkodiak May 4, 2011 09:07 AM
i got my camera wire through but its a much smaller gauge... the CB wire MIGHT go through but I'd have to cut it to run it as the tips that screw into the radio/ant base are larger then the entire hole itself without the grommet or wires already in it haha.
yloDiscoII May 4, 2011 10:14 AM
Backup camera I assume? Very cool. Got some pictures to share?
I'm going to try and tackle my CB antenna wiring today, thanks for the insight, nice to know those kinds of things ahead of time.
