Replace head gasket as preventative maintenance?
Old Jun 10, 2009 | 07:23 PM
Disbet's Avatar
Default Replace head gasket as preventative maintenance?
My husband asked me to post this for him. We have an 02 Disco II with 93k miles. It will likely have about 97k miles in October when I go on maternity leave. My husband has heard a lot of problems about head gaskets around 100k. Does that happen on most Discos or just some? He's thinking of planning to replace the head gasket while I'm on maternity leave and not driving much. He will likely do all the work himself.
Old Jun 10, 2009 | 07:30 PM
Are you sure it has never been done before. Actually the gaskets can fail from 60K on and may go into the 140K plus range before it may quit.
I wouldn't do it just to be doing it if it were mine.
Old Jun 10, 2009 | 07:41 PM
Disbet's Avatar
As far as we know it has never failed. We got it at 68k and he said there didn't appear to be much engine work that was done. I don't think he realized it could go to 140k before they quit. He'll be happy to hear that. Thanks
Old Jun 10, 2009 | 08:22 PM
jycsalas's Avatar
the head gaskets will only last that long if you flush the coolant every two years. When was the last time the coolant was flushed?
Old Jun 10, 2009 | 09:04 PM
Disbet's Avatar
I'm not sure, but I'll mention the coolant to my husband. I think he flushed several of the fluids shortly after we purchased it.
Old Jun 11, 2009 | 07:20 AM
DiscoJag's Avatar
Head gaskets are not a maintenance item that wears out. It's usually another problem like overheating and/or warpage that causes them to let go. If you do the coolant flushes as mentioned, keep a good thermostat in there and keep up regular oil changes, there's no reason to believe the head gasket will be a problem. Just be aware of the truck's condition.
Old Jun 11, 2009 | 08:23 AM
okdiscoguy's Avatar
X2. Keep good coolant in it and stay up with the maintenance. You don't have to change head gaskets until they fail. I would leave it alone as well...
Old Jun 11, 2009 | 08:58 AM
hazletbassist89's Avatar
The problem with the headgaskets in DIIs is, as mentioned, the coolant. Dexcool becomes extremely corrosive if not kept up with, so as preventative maintenance you'll actually want to do a coolant flush and refill up with some fresh coolant.
dusty1
Aug 25, 2013 07:02 PM
north_nm_rover
Mar 27, 2013 01:44 PM
criticalmassey
Jan 28, 2013 01:29 PM
Pwn777
Mar 31, 2010 09:20 AM
mwindth
Feb 28, 2010 11:11 PM
