245/75R16 tires on stock wheels
Old 10-17-2012, 01:01 PM
Draayer's Avatar
Default 245/75R16 tires on stock wheels
I have a 2001 disco with stock tires and stock ride (no lift) The tires on it are 255/65R16, they are good road tires but I want something more aggressive and dirt friendly. A friend told me about tread wrights (they are re-tread tires) My friend bought some and loves them. I can get some aggressive mud tires for $108 each and the size is 245/75R16. Will I have any issues putting these tires on a stock ride? The other option they have is 285/75R16 but that is even further away from stock. So I'm looking at a little more narrow tire and a bit taller (29.05" diameter vs 30.46" on the 245s). I know the speedo will be off by about 4 mph, what other issues will I have? Will they rub? The disco is for playing in the hills and running around town some.
Any feed back would be most appreciated, thanks.
Old 10-17-2012, 01:05 PM
Bamberson's Avatar
You should be just fine, I was running 265/70/16 on stock suspension with no problems at all, not even close to rubbing.
Old 10-17-2012, 01:14 PM
suzukisam967m's Avatar
I just put them on mine a couple weeks ago. They fit great no issue over bumps or anything...you'll be fine
jafir's Avatar
Also, looking at treadwright's website it seems that all of their 245/75R16 tires support up to an 8" wide rim, so you should be fine there too.
Old 10-17-2012, 01:42 PM
jbarr89's Avatar
running treadwrights in that size right now on stock height suspension. only issue is turning hard right they rub, not so turning hard left; guess i could adjust the stops but haven't yet.
Old 10-17-2012, 03:52 PM
sorry i should clarify. I put that size.. not that tire on
Old 10-17-2012, 08:48 PM
Rover_Hokie's Avatar
I had 245/75/16 on stock suspension, and the only issue I had was a slight rub on the bottom of the wheel well plastic liner on the front side of the front wheel wells just behind the front bumper when I turned. All 245/75/16s are not the same size, so that may to may not be an issue with your particular tire, but very minor rubbing in any case.
Crcashman
06-06-2020 09:15 AM
FantomRover
12-04-2013 07:50 AM
oysterhead
12-30-2009 05:32 PM
Switzer
09-01-2008 03:21 PM
Quick Reply: 245/75R16 tires on stock wheels
