Replacing brake pads, do I need new bolt?
After recently moving to the Sierra foothills, I quickly realized that I need to brake pads. These ones are now squeaking, sometimes even when I'm not braking. Also, they get very hot, very fast.
So, I figured I would put in a new set of Akebono's. I've never installed a set of brake pads before, but from readying the RAVE, it looks like a pretty straightforward project.
Here are my questions:
(1) Will a C-Clamp work instead of the "LRT-70-500" tool referenced in the RAVE?
(2) RAVE step 7: Ensure flats on guide pins locate with lugs on caliper housing. fit new pivot bolt and tighten to 30 Nm (22 lbf.ft). Do I need a NEW pivot bolt?
Thanks
Max
Thanks
Max
According to Land Rover it is not recommended to turn your rotors. Some people have and have not had any problems. Your service limit for the front rotors are 22 mm and the rear 11.7 mm.
