-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Replacing the plastic cover inside the door (https://landroverforums.com/forum/discovery-ii-18/replacing-plastic-cover-inside-door-97531/)
mr. choodles Nov 13, 2019 04:26 PM
Howdy folks,
Has anyone figured out an alternative to the plastic cover that sticks to the door frame? Given the age of our trucks, that plastic is getting old and the glue is pretty nasty. Perhaps it is possible to create an alternative that is easier to remove/replace... Has anyone done anything like that?
Sixpack577 Nov 13, 2019 04:39 PM
I think the glue is butale tape, and you can buy more plastic at a hardware store.
You can clean off the goo and go back with rtv silicone that easily peels off when dry.
It's the easiest way to keep drafts and moisture out.
Extinct Nov 13, 2019 05:30 PM
Yes I have - get the carpet protector from Home Depot. It is on a roll, 24" wide, adhesive backed, quite thick and not brittle.
Best4x4 Nov 13, 2019 06:56 PM
Shower curtains work
OverRover Nov 13, 2019 07:16 PM
Home Depot / Lowe's has 6 Mil Clear or Black Plastic Sheet in many lengths.
OR use some cut in half Contractor Clean-up Trash Bags. :cheers:
https://cimg9.ibsrv.net/gimg/landrov...81fc20927b.png
