Replacing Stub Axle - what other parts needed?
Hello,
So, I'm in the process of replacing my left rear stub axle ('97 Disco), due to damage cause by a busted wheel bearing (which of course I'm also replacing). My question is: Are there any parts - like seals, etc. - that should be replaced with the stub axle? And do you have source / part number(s)? From what I can gather, there may be an oil seal that needs to be replaced. Also, when I searched for 'stub' on Atlantic British, there is a 'bearing stub axle swivel pin housing' - do I need this? Thanks for any help! Mike |
Hope you haven't orderd your axle yet, check out http://www.roverlandparts.com/rearaxleshafts_1.aspx $50 for a used axle.
Originally Posted by Disco Mike
(Post 113007)
I've been ordering other parts (bearings, etc.) from Atlantic British... Thanks, Mike |
